Wire tuck under plennum
Been test fitting the polished plennum and I think I would
Like to do a cable tidy while I'm at it !
what i would like to do is split the main harness into
two branches that can go down each side of the fuel rails !
doing this would be neat and hide all the cables, is this safe to do ?
Lee if you have enough piping left over to do another water by pass once you have finished with what you need, PM me matey, ill have it off you. so i can do mine.
Well the hoses i bought are fairly high end stuff just to get the best effect !
I got them from ebay
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=250469459577&ssPageName=STRK:MEWNX:IT
likely cheaper options out there but i've used them plenty times before
and there hoses are top quality.
It was round about 30 bux to get the hoses and clips i needed for the bypass !
so 3meters in total. lol i sound so noobie, wouldn't really know about the water by pass as I've only ever investigated it using Jeff's photos, the first time i looked i couldn't even make head nor tails of where the bloody things where routing too.
Watching this thread with interest as I am going to be doing my soon. (Well as soon as I get the spare plenum finished.)
Incase anyone else is thinking of doing a plenum pull there is some good info here taking you right through the whole procedure.
http://www.fairladyz32.com/downloads/images/manuals/plenumpull.pdf
Edited by bigh
Shinny new red silicon pipes arrives today !
I can now do the water bypass properly, hoping to get this done tonight !
Now i know i can safely [touch wood] chop up the harness i might do this too.
I'll post some pics on my project page when its done.
Hi bud, I meant the hoses I sent to you to swap :thumbup1:
Sorry mate , there fine thanks
Heads in a different planet there !!
Nice one. I posted them ages ago and got worried as I never heard from you, glad your happy
Looks like a spoke too soon !
Came home with a view to fit the water pipes,
I put on my wooly hat and a big warm hoody ready to do some quick sub zero work
only to find the pipes are too bloody big, big in that the silicon wall of the pipes is
far too thick and you can bairly bend the damb things.
O well back to the drawing board !
8mm id silicone pipe is what you need,it doesnt have to be reinforced either as the normal stuff will cope.id use the Stock nissan pipe clips too,they are sprung for a reason.as the pipe expands and contracts the clip will retain tension on the pipe whereas a jubilee wont.I know people that have used jubilees ok but id imagine after the pipe had shrunk they could work loose.i prefer the clips and think Nissan used them for a good reason imho.
Good point!!
Looking good buddy!!
Done the wire tuck today and chopped up the loom in order to hide the cables
under the plennum also fitted the new water pipes too.
Heres a few pics :
After your recomendation i stuck with the standard clips rather than the jubilee type !
Makes sense !
