Aircon pod lights not working????
Hey got a prob with my aircon pod, all the features work eh aircon heater hazard switch wipers etc but none of the button backlights are working?? anyone had this before? will take it off tonight and chech connectors.
thanks
Craig
You might have one of the little pins bent on one of the multiplug connectors or a break in a track. When you take the pod off, undo the 2 screws on the back cover and have a close look at the board. Also pull off the 2 multiplugs and check the pins.
cheers Graham I thought it might be something like that ill have a proper look tonight.
Thanks Craig
Just a quickie and probably a stupid question, did i convert your pods?
No thats cool, its just that i had some dodgy red leds at one point, i found that the anode leg was wrong and they were fine on their own but wouldnt work in a circuit. They were sent back when i found out lol
Do you the rest of the dash lights work? If you had a fuse blown for instance, it can affect the on/off lights. Although they work independently of the main lighting circuit, they have a dim effect when the lights are turned on.
well the digital display works the auto button works i think and the windcreen heater, Its all the rest on the pod, like youve said its probaly a loose connector or something, I Have a spare set of pods on my breaker so I can try them aswell
Yes if you have a spare pod, give it a try, im certain it will be a board problem and probably nothing glaringly obvious.
