Me again.
So I have two questions:
RobHowl ·
Hi
Does anyone know whether z31 turbo front discs fit our n/a early z32'.
They are both 280mm diameter and 26mm width. I urgently need some cheap early n/a discs to get my car through its MOT.
thanks
Mark
