Plenum water bypass?
I've got the plenum off at the moment and want to do the water bypass, but I'm a little bit confused as to what I can remove and what the bypass actually bypasses? if that makes sense.
Are the pipes i've arrowed the ones that will be bypassed and can be removed?
iirc they send warm water around the throttle bodies for if the car is used in extreme cold climates, something like that, and it elliminates unnecessary pipes that could fail, and makes it a hell of a lot easier to remove/re-fit the plenum in the future..
only hot water goes through the water pipes (once warmed up anyways) :) I'll be doing mine soon too, got a leak on a cam cover, so might as well do it whilst the plenum is off....
