Turbo Rebuild
nice find, if you want those turbo's you gave me a while back John I still have them. Just ask if you need them.
That would be good if I can. Then i can play 1st before rebuilding the good ones.
That looks good but would the turbos not need balancing on a machine? I didnt see anything about that on there
No probs, not sure if I'm done you're way for a while but you're welcome to pop in for a cuppa if you're in the area John.
you're right, they will need pressure testing and balancing before the go back on the car.
another point to consider is, why are they being rebuilt?, has the turbine shaft been worn, is the core in good condition? or, are the end casings fine?
it's one thing to rebuild tubs on the bench but, it's another thing to get them right ;)
Can get them tested and running fine for ยฃ45 with postage there and back. Turbos are fine but the the rear oil seals have gone.
