Car will not drive above 2000 revs
HI FOLKS
FIRST EVER POST!
i am stumped, 1989 import tt manual, hot or cold car starts and runs perfectly,when you pull off ,will not rev in gear more than 2000 revs ,if you dip clutch will rev cleanly through to 7500 revs, engauge gear will not rev ,you can drive slowly provided you change up the box before you hit 2000.
had series 2 ptu 4 years ago may 4000 miles use
new air flow meter
engine rebuilt 1500 miles still running in max 5000 whilst driving
new coolant sensor 3000 miles
this fault has been on car to some degree for last 10 years but very random ,used to clear when it happened ,if you sat with engine running for a few minutes and would not occur for months ,now perminant
as i said i am stumped any ideas folks ?
as above,
Is your maf genuine nissan part, I believe patern parts can be dodgy on our cars?
It sounds like a faulty maf and its in get me home mode
thanks lads i thought it was in get you home mod ,fitted the new genuine air flow meter this morning now change
You will have to reset the ECU to get it out of safety mode, do this by disconnecting the battery for 1 hour and then reconnecting.
But before you do that, under the passenger foot well carpet (up against the foot rest) remove the 4 bolts holding the piece of wood over the ECU, on the side of the ECU is a little screw you will need a flat head screw driver. turn the screw fully clockwise, then wait 2 seconds, then turn it fully counter clock wise, then sit and watch your engine light on the dash, you will get long flashes, (first number) then short flashes for the second number, take a note, even if there are more than one code. reset the ECU, take it for a drive, then check the ECU again too see if the codes flash up again, if it does 5 long flashes followed by 5 short flashes, its all clear. if not post up the codes.
hi vodkashots
code read ecu ,55 unfortunatly ,disconnected battery just too be sure reconnected drove car still in get you home mod ,reread code still 55,
any more ideas
scant
