protoj · Tuesday at 18:48 2 days
I heard this many years ago, didn't hear it for years, and accidentially came accross it last night, it's not really offensive, but if your at work, turn the sound nice and quiet :) Childish but poetically funny, hehe.....
http://www.youtube.com/watch?v=XAJroAaf3ZY
