Front calipers
Are the front brake calipers the same on a J spec TT and a J spec NA ?
It depends on the year.
Pre 91 NA's have different calipers for 28mm discs. Late 1991 onwards are the same as TT calipers which use 30mm width discs.
But there is some crossover between years, and you cant rely on the V5 registration date. Needs to be measured ideally.
From 93 onwards the Calipers were changed from Alloy to Iron.
