Progress so far
Well had the car a week now and so far done a lot of stuff too her.
Had the car on the ramps earlier and as much as i loved the sound of the single exit, my mind was made up that it needed to change. not because i think duel look better (which they do) but because it had a blooming hole in it.
Well So far since owning her this is whats been changed.
- UK rear seat belts now installed from my black one.
- LED side pods installed.
- Passenger side window switch changed over as the one it originally had in was lifting
- Rear 99spec mod done (although now needs redoing as the damn pin stripe is lifting just like i said it would lol)
- Passenger side wing sprayed and changed.
- Windscreen wipers changed over for the ones off my black zed
- Windscreen weather strips changed over
- Duel exit mongoose system fitted to powerflow decat pipes.
- tried to clean the wheels lol
Today i also found the power steering fluid pipe that was leaking, and I'm pleased to say its the same one that runs under the cars front sub frame as what my N/A leak was coming from, so at least i know its a easy change, even if its a bit fiddly.
Anyway here's some pictures of her. going to get a better picture of the dash all lit up tonight.
holes in the single exit :(
  • Replies 27
  • Views 1.1k
You cant read lol, i said i changed the wipers over, IE: the whole unit, arms included. Paint work on mine were better, and for some reason my UK spec one came with a wind deflector on it. helps keep the blade on the screen in the rain at high speeds (not illegal speeds, just high speeds) and adds a nice touch.
WOW!!!!!! :tt2::tt2: :lol:
ok if you must know, it took me all of 5mins lol
Anyway had the fun of taking the power steering pipe i needed from my breaker today, was hoping to get it on the new one so i don't have a power steering leak. what a bloody ball ache. it is the same pipe i changed on my N/A, only difference this time is, you have all the turbo pipe work to contend with. :( and the hassle of having to try and feed it through blind to under the car to get the thing free.
Got all the fun or removing the other one tomorrow to fit it.
