brake light on
I have a issue, was driving the car this morning and noticed that the brake light was still on on the dash, so pulled over and checked the hand brake but it had released all the way to the bottom of its travel. also check the fluid level in the engine bay and that was half way between full and empty.
Now i cant remember seeing a ABS sensor or anything, so do we have them? take it its time to change the pads?
stupid answer mate, are you brake bulbs good. mine were ok when braking but the element for when lights were on had gone, caused the brake light on dash to light up.
the ABS sensors are on the rear diff and behind the front hubs mate.
Nope separate light for that on the dash called "lights" lol
Thanks Dave. have a feeling its not ABS though, but those little pin type things that warn of brake pad level low might be the cause fronts are looking a bit low, think ill jack the car tomorrow and whoop the wheels off and check the pads.
IIRC Z's don't have pad wear indicators, light comes on with low fluid and park brake.:confused1:
strange, fluid ok park brake off, unless my drums are sticking? yet the handle only comes up 8 clicks before its fully on. unless its just not releasing properly? wheres the switch for the light? could be a sticky one?
On the lever dude!-bet it's that..............
yay any excuse to play with my leveler, ill have a look in the morning.
Still debating if i should put my twin exits on over the single exit as well. but car has to go in the air tomorrow as i need to chase a power steering leak that has gotten quite bad.
