Dont start after 2 weeks in garage...?
Oh boy, did a mistake and need your help !! - did not drive my Zed for a couple of weeks... she is paying me back and refuses to move out of the garage ;-(
All I get is in the beginning just a couple of secs sound that at least something is happening, but the engine stalls completely when releasing the key. If this would be only one coil/cylinder then it should start but run uneven - or ?
Tried with some extra power (electricity) from another car, but all I got was a lot of gasoline smell from exhaust - so I guess the problem is in electronics?
Having had my Zed only for a couple of months I really dont know where to start... can you advice how to wake her up again ?
PetriK
Hi,
You tried extra power, good. Hopefully you gave your battery a chance to charge for a bit. The 300 needs a LOT of power to start due to the compression.
Number one, do an ECU diag. Check www.twinturbo.net in the tech section for info.
There is so much to check I'd reccomend reading a service manual...
The car will run on 5 cylinders, I don't know if it will start on 5.
