Best offsets set-up?
Hi all, ive been looking for some new alloys or second hand ones for nearly a month now and they are a few about i like they are 17 x 8 with a 35 offset and a 18 x 8.5 with a 30 offset.
Which would look best and sit best on the car?
cheers
James
the 8.5j et30 is a better offset but in my opinion is still not agressive enough...
my fronts are 8.5 with 35 offset . to bring flush they would need a 15mm spacer so ideally you want an 8.5 with a 20 offset . rears are 9.5 with 35 offset and they sit spot on flush . they are 18,s by the way
30 sits better than 35. A good look with a 8.5inch wide wheel is ET20. Only problem with aggressive offsets is the risk of scuffing the alloys is much higher, the crap from the road gets sprayed up in the wrong places and some stones directly hit the metal lip on the arches leading to faster rusting.
Also using spacers does increase the load on the wheel bearings.
Each to their own and all. I agree the OEM offset is pants, but I've gone for a less aggressive offset for the reasons above.
