pulling to the left
Hiya my car keeps pulling to the left, spotted that the passenger side tyre is wearing on the inside edge only, supposedly had the tracking done at ATS, could this cause the problem, have done a pad change to eliminate the calipers etc,
cheers Jon.
Check the bushes around the steering area.
If they are worn they could cause the car to pull
Stuart
Also, check the condition of your shock absorbers.
Bounce the car on each corner and if the shocks are toast then it will continue to bounce.
simon p
1st, Check air pressure in tyres.
The recent alignement check sounds suspicious to me. Its very easy to get this wrong. The toe-in adjustments are the most common cause but a negative caster on one side will cause this. Get it checked again.
Like the other guys said, get the shocks, bushes, tie rods etc checked at the same time.
