Does anything fit in the space which is on the drivers side at the end of the seal?
Is there supposed to be a seal or anything along the holes on the bonnet edge (6 holes along the edge nearest the screen)?
Is there some sort of bracket for the plastic ducts/vents that sit either side of the boot? For some unknown stupid reason, the second bodyshop decided to remove them and I'm sure there's a bracket.
Vijay
there should be a bit of foam over the last wing bolt and i think the trim should carry on around the corner. on the bonnet there should be a seal which clips into each of the holes and runs across the back of the bonnet
as i said on the last post,there is a seal along the bottom of the bonnet and one on the leading edge.:biggrin:
Think you're right about the foam bit and the trim just meets it.
I've been looking at pictures of some bonnets and can't see anything in those holes. There is a small rubber trim that goes on the passanger side and one that is the complete width on the front of the bonnet. But I think that's it????
Vijay i had the left side duct out of the boot today and it is only mounted with 5 screws. you insert them from the bottom up and then have 4 screws that go into the bottom into plastic fixings in the chassis and then the one screw in the top from inside the boot.
Marty
Hi Marty,
Thanks bud. So they fit fron underneath the car and not from the boot?
Vijay
Hi Marty,
Vijay
yep there will be holes to fit them up into then just the screws
cheers Marty, I'll have a look tomorrow if it doesn't rain
