many thanks to all - thius would not have been possible without the help of you guys -
i have finally got it all back together but have a few niggles that i need more help with being a manwell virgin,
The clutch bites about a 3rd of the way up and in first feels very heavy and as i am letting out to find the biting point it vibrates a little and lurches - seems like i am fighting with it
when first started the car idled about 750 rpm but now idles about 1500-1750 once warmed and stopped at lights
I have a noise thats sounds like its directly beneath the gear stick - sounds like a heavy rattle at lower rpm (when driving and under load) but when throttling off you can drive through it
God awfull vubration about 45mph through the steering wheel (wobble) - if this is prop is it centre bearing (i left the one on the donor half) or does it need splitting and turning - if the turning option do i have to turn in increments of 90 degrees or 180
It has a new "Competition Clutch" so could the biting issues be this running in or is something else wrong it also has a new clutch release bearing and gear changes after first feel fine - bit notchy but fitted a short shift as well - as always all help much appreciated
dave
