Filament spec number....
Can anyone tell me the spec/product number of this filament/bulb. It is from the map lights and I want to get an led replacement.
Cheerz people,
Al.
Its a T5 Al. You want to get the 3 way T5 smd led available on ebay. The advantage of the 3 way is that it has an led at the end and one on each side. You virtually lose the use of the top one cos of the angle of the bulb. Failing that, Martin (zedwizz) has made some led boards that he designed specifically for the map lights.
http://cgi.ebay.co.uk/T5-3528-SMD-3-LED-Wedge-Dashboard-Light-Bulb-Lamp-12V-/140456905215?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item20b3e249ff
You might need to trim the holder part, they are usually too long.
Graham
Edited by groover
Cheerz matey, i knew i could rely on you for this info.
Al.
