Sound system install, tips and tricks?
I'm finally making a start on my sound system tomorrow, was just wondering if anyone knows the easiest place to run the power lead for the amp. not sure if there is a easily accessible grommet in the passenger foot well or not?
any tips and advice would be appreciated.
Steve
follow the AIV pipe work into the wing. then either run it through into the passenger foot well using the whole for the Targa drain (be careful not to disturb the pipe from the target connected to the drain point) then run the cable from the passenger foot well to where you need to be. the wing will need to be removed though to gain access unless you can do it with the wing on (just harder and more time consuming).
That's how i would do it, but I'm sure there is another way as my alarm system runs through the firewall into the engine bay, just haven't really had a look how they have done it.
