Front Camber Correction Kit Group Buy
I'm organising a group buy on Front Camber Correction Kits for all of us with front inside tyre wear.
A lot of Z's suffer from camber out of specs.
With too much negative camber the car doesn't drive in a straight line very well, has less tread on the road and the insides are worn out very fast.
The reason for this can be wear or damage in the suspension, the use of lowering springs or non-standard wheels.
This is an alignment problem which can't be solved at your local tyre centre because the camber can't be adjusted on a Z.
The Kit contains 4 brackets which replace the original ones, 20 shims for adjusting the camber in steps over a wide range (up to 2 degrees), two washers and instructions.
A table tells you how many shims to use once you have had your camber measured so should only need to be tested twice - before and after fitting.
All metal parts are laser cut and zinc electroplated.
The original nuts are re-used.
This kit should be able to deal with most camber problems.
I've got 3 people already wanting them so add your name to the list.
Almost everyone I know has this problem!
Price is £35 all in for 10 or more sets.
This is a bit of a bargain compared with the Stillen adjustable upper arms at over £400! If I'd got one of these kits earlier it would have saved £200 in otherwise un-worn tyres...
[This message has been edited by ChrisC (edited 01-09-2002).]
  • Replies 37
  • Views 1.4k
Originally posted by ChrisC:
Kin hell! 21 sets now... is this the forõm group buy record? LOL biggrin.gif
LOL I was just going to say that!
KEEP IT SIDEWAYS;).
Originally posted by syko:
count me in
ta
ROLL UP ROLL UP NO MORE BALD INSIDE EDGE FRONT TYRES ANYMORE!
We need a new forum record biggrin.gif.
KEEP IT SIDEWAYS;).
This is going to be a nightmare to organise I can tell!
Can everybody please write their name, forum name and their delivery address ON THE BACK OF THEIR CHEQUE please so I know who has paid and where the hell I'm sending all this stuff.
It might be best if you also mail me with these details to:
chris.carter@orange.net
Thought you knew how to do that Liberace biggrin.gif.
KEEP IT SIDEWAYS;).
I've mailed everyone on the address in their forum profile so let me know if you haven't received anything.
Import Ant - I got an auto response saying you are out of your office for a couple of weeks - Send me a mail if you read this before then.
I will take a set Chris - mail me with the details/payment options as and when.
I would advise anyone who is changing/changed their wheels for non standard wheels - and/or springs to purchase this upgrade.
Well done, and thanks again for this GB.
AndyGP
Oooops double post - DOH!
[This message has been edited by AndyGP (edited 08-09-2002).]
Errr....sorry....been away a while....am I too late to be added to the lengthy list??
  • 4 weeks later...
Just to let you all know I'm still waiting for the kits and will send them out as soon as I can.
P.S Still haven't had cheques from quite a few of you but I'll mail you all when I get chance to work out exactly who you are!
Chris,
I think Mark (Topless) may be interested in a set.
Chris,
If its not too late, can I have a set too?
