Hi guys.
I have one installed but i dont really understand it.
Ive downloaded the manual and given it a thorough read through, but its still no clearer.
It has 4 modes (levels of boost) an off mode, a warn mode and a scatter mode.
No idea what scatter is, i know what the off is.
Warn mode is confusing me, when i switch to it it has -15 on it in red light.
The 4 modes are already set. 2 are at 1.28kg/cm2 68%
and the other 2 are at 1.28kg/cm2 57%.
When i floor it it goes to 18psi on my aftermarket gauge on mode 1. I know thats not standard, but i dont get what the controller is telling me, its in kg/cm2
I cant see anywhere if its telling my air fuel ratio.
I need a techno genius to guide me into what this all means.
Any help much appreciated
Mark
18psi :ohmy: Hope you've got the appropriate mods mate to run this level of boost. If not, probably safer to run at 14psi.
Not sure what manual you've got but I used this one which is farly easy to follow:
http://www.sr20tuning.com/Blitz_SBC_i-D_manual.pdf
By scatter, assume you mean scramble mode. Might also be worth changing your controller settings to psi to match your gauge.
Do a search on here and you'll find lots of posts on setup.
Apparently it has, its had a thorough thrashing by the previous owner and it still lives :D
Thats not the controller i have, mine is blitz but its not got the option to change to psi.
Yeah i meant scramble, i dont like the sound of that so ill leave it alone.
Cheers Zilver
