f.a.o. JEFF TT
hi jeff
remember this
Originally Posted by minder
guys,
zed had been rattling (topend it seemed) , anyway it just died last wednesday, its at a local garage who say ive got a siezed cam
no prices given yet to sort prob, ( garage is macdonald racing)
this garage specialises in restoring old morgans so there not that familiar with zeds
do you think i should just get an engine swap from jeff at zedworld
or does any of the northern guys know where i can get this done
cheers
Ok dont panic just yet, with some more information it might be possible to take a more reasonable route than engine replacement.
Ok so assuming you do have a seized cam then the previous noisy top end could have been a sign of poor oil flow to that area which has allowed the cam cap bearing to run dry.
Lets assume this is the case then the usually the belt snaps and the engine stops dead did it happen this way? also more usually at low speed so damage is often not too serious.
Has the sump ever been damaged ? not unknown for any sump dent issues to cause the oil pick up to be displaced and cause low pressure at the top of the engine.
Once established that the camshaft is definately seized then removal is the next step and inspection of the camshaft bearings, and oil ways where possible but this is where it can get expensive labour cost wise so any external inspection is a good idea first.
Having seen this very problem on a few occassions it tends to effect the right hand cams more frequently, most likely due to the design of the oil feeds to that head.
With this in mind we have successfully released cams before by gently rocking the said pully back and forward ( timing belt off ) and then the cambelt can be refitted and timed up, try and turn the engine over by hand, if this is works then a compression test can be done to establish if there was any piston/ valve contact and if ok then its a good chance that by removing the effected camshaft and replaceing with a new or known good use one and new bearing caps etc. that the engine can be saved, this of course relies on ensuring the oil ways are clear so the problem does not re-occur.
Of course damage could of been done so keeping the testing /inspection to the above tests etc is not too bad if it does need a replacement / repair to the engine.
Good luck
Jeff TT
__________________
ZEDWORLD
Priority vehicle ConZult and fault testing service for all subscribed 300zx members....... book now!
JeffTT
View Public Profile
Visit JeffTT's homepage!
Find More Posts by JeffTT
5th August 2010, 15:17
can i book my zed in to get it sorted can u give me a call on 01914914745
u did the turbo,s three years ogo,
cheers
ken
No posts to show
