Removing scratches on glass
Hi all,
can anyone recommend a compound that will removescratches from glass (or at least reduce their appearance?
I have a few scuffs on the driver's side window of my ZX; and I also seem to have got a light single scratch about 5 inches long on the driver's window of my SLK.....
Thanks,
Richard:pinch:
Hi, I'm also interested, both of my door windows have lots of vertical scratches in them, whats caused this? i've not had a reason to take the door cards off yet, but something there must be scratching there when the window are down..
Cheers (sorry for thread stealing)
Sky
Ive bought some off ebay but i have yet to use it lol!!
Sky
I've got the same type of scratches in both my door windows...i'm pretty sure its down to the rubber seal which goes across the top of the door...as rubber ages it goes dry, brittle and rock hard. I guess over time all the ups and downs of the glass against the hard rubber causes all the scratches....
My 2 penny worth.... :)
Sean
I've got those scratches pretty bad as well, I assumed that some sand/grit must have got down between the rubber and the glass.
Car.Mad, hurry up and use it, we're all waiting!
Sky
No worries mate - it looks like a common problem!
LOL - at least tell us what you have bought!! That way someone else can try it and let the rest of us know. Since you can't be bothered......:tt2::tt2:
Richard:whistling:
I too have scratches when they catch the light that are vertical on the drivers side :oops:
On my 1991 MX5, they are notorious for winding up and down very slowly puttting stress on the cables and motor :thumbdown: I sprayed or drenched wd40 or similar on all the window rubber guides and they go up and down a treat, repeat every six months or so :yes:
My brother inlaw uses tooth past to clean the scratches on his motor bike helmet
Don't tell me he use T-cut on his teeth LOL
This is the one i bought http://cgi.ebay.co.uk/NEW-Windscreen-Scratch-Repair-Kit-Glass-DIY-Remover-/280557946301?pt=LH_DefaultDomain_3&hash=item41528e85bd
Its only a small little bottle you get and it looks like milk lol!!! tidy little kit.
Not sure how well it will work on mine because mine are really deep scratches. but we will see :yes:
well a tip i picked up on the volvo owners forum was brasso if it is light scratching or jewlers past if it is deeper
Sky
Remove the outer seal running along the top of the door frame - it is probably caked with dust & dirt - clean with soapy water & blast out with a pressure washer then allow to dry - it should be a nice soft felt! :yes:
