air con fan
while ive got a bit of spare time ive been going over the old girl swapping and changing bits and cleaning connecters etc . general tinkering before a planned long run . i,d like to check the operation of the electric back up fan / air con fan . is there a simple test process for this to check its working ok
cheers
Pull the temp sensor connector off should start up then, make sure you get a good connection after though.
Jeff
is that engine running up to temp or just ignition on jeff. am i likely to get a pisser of the connection because its no longer got the original plug on it , just a couple of spade connectors
No issue with getting a shock, you only need to pull one of the spades off to activate the fan, engine running or just igntion on will be fine, if it does not run check the fuses in the relay/fuse box on the passenger inner wing marked fan and sub fan.
Jeff
Jeff
nice one jeff . cheers mate
