Name whats wrong with your car at the mo
Surely no-one's car is 'perfect'... so spill the beans and tell us all what problems your Z currently has - big or small :cursing::cursing:
Do not include servicing and basic maintenance, or bodywork issues.
We may even be able to help each other if someone has a problem that you've had before, or vice versa.
Currently - my gearbox is whining and making funny crunching noises occasionally... I have a replacement sat in the garage along with a Z1 Lightweight Flywheel & Exedy Paddle Clutch ;)
My car 'winks' when you flash the headlights, so that needs sorting (bulb is ok) ;)
Central locking doesn't unlock the passenger door, but it does have an old clifford alarm that I think came off Noah's Ark :sleep:
  • Replies 62
  • Views 2.4k
Bumper needs re-aligning.
Every now and again it sometimes holds back at low throttle settings (once a month maybe!). Not sure what it is, I think its a lazy O2 sensor. If you prod the throttle its then fine. Most weird, (im begining to think its my driving style that does it as my old one did the exact same thing!)
Its wrong because it needs 99 spec rear lights (have 99 centre panel to fit tho!)
Also need to get on with the interior retrim!
Bit like Jimmy not much wrong :tt2:
I do want now at my leisure some SMIC's and larger injectors, but not in any great rush, oh it could do with vaccing out!!!! :winkiss:
Have removed high level rear spolier, and side skirts, going smooth all over. new n/s wheel arch to be welded in. then a bit of paint.
apart from that the everything else superb. runs perfect.
does no one use evostick for interior re-trimming??? Or is the material too thin!
i used that stuff and found when it got a little warm during the day it would go gloopy and the material would sag in un-supported areas :sad:
Nothing except its half Bayside Blue and Half Grey Primer, and has been for about 18months
Drivers side window won't work and I replaced the window regulator so its not that.
Heater Matrix to be fitted.
Occassional issue with front indicator in that it doesn't work from time to time. I cleaned the bulb holder to give a good earth but it didn't rectify the issue.Must be a loose cable somewhere, and I think it may be under the wheel arch, as when I went at the side indicator lights to check for the connections to replace the carrots with the clear lenses, the problem has started to happen less frequently.
Right here goes.....
AirCon dont work - Being Removed
Drivers door lock dont work.
Dissintegrated rear brake lines - Due to rust
Need to complete Plenum water bypass
Fit new rad and pipes
Finish removing AIV, EGR, C. Canister etc
That dont include rust, not major hopefully.
Think thats it thank god LOL
heater matrix bypass, thats all:D!
major oil leaks, doesnt idle doesnt pull, runs on all cylinders now but sounds like death. pas lines leaking, sitting on stilts, no tax no mot. currently booked in with zedworld for the 6th to get it all sorted :D hello loan
both outer sills rotten
diff leaking
rust over the rear right arch
rust under fuel filler
water leak under plenum leaking onto coilpack 3 causing it to missfire occasionally
tension rod bushes slightly worn
badly curbed nearside front alloy
filthy engine
reverse lights work when they feel like it
paint peeling off rear bumper
no fan cover as that jumped into the fan on the way home from buying the car
stinks of petrol some times
tear in drivers seat.
thats about it i think
still got a resistor bodged instead of the knock sensor. other than that i don't think anything actually "needs" doing to it.
diff leaking
filthy engine
Hey Rob,
That lot is gonna cost you lol.
Will you be doing all the work yourself mate ?, i hope you got it for a good price considering all that has to be done.
Cheerz
Chris
rear springs not sat on their seats properly due to hump back bridge, stupid rediculous un-needed nothing but hassle poxy hicas needs replacing wih a non moving hicas!!!
Horn stopped working halfway through beeping at someone. and, need to get the decats. then its ready to mot when i can be bothered
Diff cooler leak but will prob bypass it with some copper pipe and a couple of jubilee clips
Drivers rear arch bubbling
Slight boost leak on passenger turbo intake
power steering fluid leak, somewhere? i need to get it sorted rather than just keeping it topped up.
other than that for a car with 138,000 miles on original engine AND turbos it goes very well,
my vert doesn't have turbos
the roof doesnt come off my TT
neither of them are the 370 roadster i test drove yesterday
[sIGPIC][/sIGPIC]
car keeps cutting out when you come to a roundabout etc sometimes it ticks over for 5 secs and then cuts out but always starts straight away
mine was doing this until recently . i put a new fuel filter in and touch wood it aint done it since .
Hmmm!
Well, when I bought mine, I knew there was a list of things that'd need attention and some 'nice to haves' that I'd planned on 'working' through gradually but I seem to be perpetually running round trying to fix the things that are breaking that I didn't mitigate for.
It's currently sat in my office car park in Surrey leaking most of it's fluids on the ground. Coolant leak from the rear of the engine, fuel leak from somewhere, (stinks!), and a PAS fluid leak to boot.
Got a man with a spanner coming to have a look at it tomorrow. He was meant to do it on Friday, but when he arrived he drew air through his teeth and admitted he got it mixed up with a 200SX and would need more time.
(I strongly suspect there was a 'Kerching!' in there somewhere!! :cry: )
