Seem to still have an issue where as my steering gets so haevy [usualy when trying to park] that its like the car has stalled!!!
ย
Replaced solinoid on rack drain flushed system twice looked threw search and there is a mention of a ecu for steering ....so thought i would ask:tt2:
ย
Dave
Dave just a thought, it may be a speed fault on the sensor circut and the car thinks its doing 160mpm so giving hard steering.
ย
Allan
Whats the harm in trying a different ECU? It'll be an easy 10minute job and the cost of one from a breaker will be peanuts.
Give it a whirl if you think it might solve the problem, the worst you'll loose is ยฃ10/15.
ย
Personally though, I think its unlikely to solve your problem. Is your speedo working correctly?? because this is where the PAS ecu gets its signal from NOT directly from the speed sensor.
ย
Allan
ย
Hi Allan would you know how to check this out for faults??
ย
ย
Speedo is spot on matey
