Idle high when warm
Evenin all,
Just got back from a bit of a blast tonight, while the turbo timer was running down the engine was idling at about 1300rpm. Also noticed it when i was waiting at some traffic lights just befor i got back. Tried blipping the throttle to help it settle, but stayed at a constant 1300ish
Any ideas?
Checked the throttle springs, but not long since i WD40'd em...
could be a tps issue
Easy Damo,
TPS? Throttle Position Sensor? Sorry, still learning the jingo. What does TPS stand for?
yes that right mate, check your throttle is not sticking also. When my idle played up i had a slight boost leak.
Righto - will investigate
Check accelartor pedal isn't sticking slightly, put ur foot under and pull towards yourself.
did you have the aircon or heaters on?
dan.:cool3:
dan.:cool3:
air con was off, but the radiator fan was blowing more than usual, probably because the engine was quite hot - but not excessively so. Does this affect the idle at all?
cheers
Will fire her up wheni get back from work and see what's what. Will give this a go...
cheers
Check that ECU temp sensor, that causes the air con fan to come on
Will do - Thanks
Yes Robo, great site that is
:clap::thumbup:
dan.:thumbup1:
Evenin fellas (and gals)
Took the Zed for a short run today and the idle was still at about 1500.. I had a play with the air con and sure enough, the idle dropped back to normal. Was only a short run, but idle seems to be fine now. Gonna have a thorough look tomorrow, but I guess that this info narrows down what I should be checking?
