Turbo change
I a turbo change a engine out job or can you do it with it in?
Thanks Mark
I believe it is possible to do both with the engine in, but its apparently as much work to do them as to just take the engine out and do them with ease. at the same time there is a few bits and pieces which can be done around the back of the engine water pipes etc and crank seal which are often preventative maintainence.
Apparantly The passanger side is not to bad to do with the engine in, much easier than the drivers side.
You can do them engine in no problems.
Done Loads that way.
There are loads of post on this subject . check um out
Daz
d2
