this may be a stupid light question......
Fog lights..... I bust the back mines, so got a new one (thanks ck300,will sort that paypal out!) but how on earth do I get the wires in without disconecting from the plugs? I don't think they all unclip as only the white wire Has male and female crimps. So am I being stupid and missing something without having to cut and try obtain new male and female crimps to wire back up, I don't do soldering etc so not wanting to remove from the plugd whatsoever.
Did you go in through the indicator to remove the whole unit .Its just three nuts then you should just unplug the connector swap the unit bud
Jim
its the fog light. the new unit i obtained is purely for the rear plastic plate as the one is shattered that is on the car.
So my problem is....how to get the wiring in as there is the bulbs etc still sttached?lol.
At the moment im going to be looking to just cut and re-crimp the wires.
sorry craig thought you meant the front fog not sure about the back mate never had the panel off
It is the front im on about mate.lol!
As he said don't you have to take it off via the bolts on the rear of the unit.
Jim
Yup but the foglight plug sticks out at the back off the fog even when bolted onto the bumper plate. It's strange trying to explain as it seems so stupid.lol.
but I cannae get it in likeeeee.lol. that was an attempt at a geordie.lol
You will need to take the fog light off the bumper bar, undo the 3x 10mm nuts on the back. Once you have it off the car, there are 4 screws on the back, undo and it will come apart. The glass is sort of bonded in with silcon and remove the adjustment screw, by prising off the end glass cover. It would be a bitch to do it in situe. When replacing the glass re seal with either white or grey sealant as you will see it through the edges of the glass.
