Timing...
Just want to quadruple check this, have done a manual conversion some time ago, and set my timing to 25 BTDC, but just read somewhere it should be at 15-17 max?....
Normally timing is 15deg, however when a manual conversion is done unless the neutral switch is connected or pin 44 on the ecu is earthed or a manual ecu fitted then 25deg is correct.
Jeff TT
