Ignition Key Problem
Does anyone know of an easy way to bypass whatever stops the key from coming out unless box is in park. Sometimes mine does not release and can take me ages to get it to. Great idea when its working. F*****g frustrating when its not working. Always does it when I'm in a hurry to get out. Thanks guys. :thumbup1:
Mine can come out in any gear, as long as the ignition is off. You may have trouble with the key release button in the barrel and yes Maz mines still auto, not changed the box yet lol
Not really, its a case of taking the cowl off to get to the barrel, you may need to take the barrel apart. But before you do, try the key, turn on till ign lights light up, turn the key back to off. Press the button as normal to take the key out. If it comes out easily then it may be another problem, you may have a switch behind the brake pedal, not releasing properly, but as i said, it doesnt do it on mine.
Good luck mate
