Oil flow Rate for a TT?
Can anyone confirm what the oil flow rate [range] is for the TT engine guys? :taz:
The manual doesn't say, as far as I can tell. Just 51-65psi at 3,000rpm idle speed in neutral.
Thanks Andy - but what I really wanted to know was how much oil the pump 'pumps' - for the engines RPM range...
..For example - if I wanted to change it for an electric one ;-))
That would be crazy. If it aint broke dont fix it!
The mechanical pump is reliable and when the pressure goes above normal requirements the extra is bled off and sent through the cooler and back to the sump. Just imagine the fuse goes on your electric oil pump - end of engine in 30 seconds.
Umm yay - I never meant I would replace it (just an example) - just wanted to know the flow for some other work I am doing Willie.
