had zed 12years still a dunce
hi guys
i'm after some help again, does anyone know where i can get a wiring loom, the one that runs from the ptu to the coil packs
its a series one ptu i have which is working fine (touch wood)
the reason i need the loom is the ends that fit to the coil packs 4 are cracked and have bits of plastic missing which is now causing number 5 to miss
thanks guys
Mike Feeney at MJP, one of our traders, usually stocks those connectors.
Just undo the bolts that hold the coilpack down, pull the coilpack up with the connector on and get a cable tie under the coilpack and over the connector, just be carefull not to crush any wires as it will damage them, this is all I've done and its been fine, bit of a pikey fix but saves a few quid
