Temp up and down, up and down
- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Hi folks,
Just got the zed back today - after some suspension work
So, have been for some 'spirited driving'..
Unfortunately there seems to be an issue with the cooling system. I have a tech tom fitted so i am able to see a digital read out for the engine temp. On a motorway cruise to my mate's the temp was steady at 80-85 degrees c while at motorway speeds. However, I've just got back from a quick blast consisting of mainly backroads and then some fun on an industrail estate (roundabouts) and the temp has started being erratic.
The temp quickly went up to about 95, then all of a sudden jumped to 105, then fell quickly to 90 and then rose quickly again. This was while I was trying to gently cool the car on a steady run back to the house... I thought it might just be the gauge playing up, but having stopped the engine and popped the bonnet I saw a trace of coolant from the pipe next to the radiator cap. Closer inspection revealed more had leaked onto the belly plate and there was a small pool collecting on the floor.
I checked the coolant level and there was still plenty in, but I could hear the water in the engine (engine not running) boiling or at least bubbling away.
Any ideas? Is it the fact I may have been cornering for a sustained period to the right (ie around the roundabouts..) and forced fluid out of the overflow pipe? or could it be that the system has got airlocked somehow, which would explain the erratic readings as the sensor measured water, air, water, air etc
Car parked up now, will give it a bit of time to cool then pop the radiator cap for an inspection.
Anyone suffered a similar episode?
Cheers - Leo
