Autogauge wiring...
Hi, I have wtare temp, oil pressure and boost gauges....
Boost is simple, red, black, orange, pipe for boost...
Oil pressure has same red, black, orange, no probs, but has green for the sender, and another black and red, I pressume the black is another ground and the other red is for the ignition switch, so it lights up, but doesn't show the pressure till engine ignition is fully on? With all the blacks and reds together, the needle shoots all the way to the top, this is without a sender connected, and I know the sender puts a resistance to the gauge, so would the needle be at the bottom with the sender connected?
Water temp gauge has red, black, orange, no probs, green for the sender, and another thinner red and black, do all the reds and blacks go together? seems to work ok when they do....
Cheers.... Tudor...
What make are the gauges?
Ignore that!! didn't read the thread title properly! doh... Anyway, did they not come with any wiring diagrams?
Edited by Steams
yeah, but instead of coulours, a, b and c... the way i have wired them up makes sense, got the centre console at home, just need to know if the needle shooting up on the oil pressure guage wont do it if the sensor is in the equasion, haven't got it yet, might have it tommorrow, if know it does that, then i can go and fit them to the zed...
