Newbie form north east, got a few slight gear box noises
Its a 1990 manual twin turbo. i get a little noise in 2nd and 4th, it sounds like its wearing somthing in the box. just had the box out to replace the clutch so not looking foreward to doing it again.
i didn't notice the noise at first because there was a horrible whirring sound from the fan on the interiour light, after changing the clutch and sorting out the fan noise i then discovered the gear box noise. its not to loud, but very distinktive in 2nd and 4th only.
gear box oil was topped up when the clutch was changed so i don't think its that. any help would be greatly appriceated.
Chears
Steve
thanks dre, i had a look at that preveously, it does sound similar, i've took the leather gaitor off to check but i think in doing so it then took off the rubber ones so couldn't tell if they wer allready off. i'll give it a propper test tomorow.
I'm geting the same in mine to
how long have you had it? does yours sound like its getting worse?
group buy on 98 spec gearboxes might be in order:w00t:
how much do you reckon we'll save with a group buy?
Not enough to tempt me into purchasing one i bet!
Not so much the cost of box its the import charges!!!
If got a 94 gear box striped in my living room that I'm re building yes it is like it's geting wors but if I don't boot it I don't hear it
My gearbox has been whinning for several years now!!! I just turn the stereo up!!
I am about to drain and re-fill with "redline mt-90" to see if it helps.
Al.
Chears
Steve
Just wanted to say hi Steve as I'm in Marton, so not a million miles away from you, and got my first Z today. Hope you get yours sorted
Nice to see a couple more from Teesside area, had a n/a myself then now looking for a TT, hope you get sorted with the gearbox bud.
Mark
Mark
Wasn't a dark blue one was it? Spotted a nice looking Z in the underground Asda car park last winter!
chears guys. having read a bit more into the loose gear gaitor idea making 2nd and 4th audiable, i have come to realise that when replacing the clutch, i didn't put the heat sheild back on (basically because it was a chew on) so i think that may reduce the sound deadening aswell, so i'm just gunna keed drivning it and see if it gets any worse.
where do the north east meets take place? i should be game for that. is it just Zeds, or jappanese in general, my friends quite like there hondas.
