2 things
hi
every thing i do to the zed seems to solve one problem and create 2 more
never known a car like it !!
firstly when i got the car the key fob remote would not open and close the doors but you could hear the actuator working
yesterday the drivers door would not lock at all with the key
so today i took the door cardv off and found the actuator for the alarm had become disconected so no probs put it back on all working with the key fob
except the passenger door will lock but not unlock
also noticed a metal rod with a yellow plastic bit hanging down the bottom of the door i think this was attached to the back of the door
lock barrel and has snaped off ?
do you think the central locking actuator on the passenger door is fooked ?
as it locks and unlocks direct with the key but will only lock off the alarm fob
thks kurt
Rod with yellow plastic bit is needed, wont work sat in the bottom of the door
Edited by wow300
the rod with the yellow bar is indeed the locking rod and should be connected to the back of the lock barrel these failing is quite common on the zed, you may find someone on here that has just the plastic part if you post and ask in items wanted as that part is only available from nissan as part of a complete lock barrel, when i asked about mine (i had same problem) mr.f (mjp) quoted me around £68 for complete drivers lock barrel
thks wow300
understand i need to fix it but not sure wether that will make a difference to the passenger door issue as the remote fully works the drivers door do you think there is a problem with that oem central locking actuator on the passenger door ???:sweatdrop:
Just get in touch with JeffTT and ask for the plastic yellow rod connector clip. They are a common failure. He should have one from a breaker.
