Injector polarity ?
in a bit of a dillema:
When removing the injector connectors to replace with new ones I noticed the following:
There is one thick and one slightly thinner wire leading into the injector connectors. Looking at the connector with the semi circle cut out facing you
the thicker of the two wires leads into the right hand side of the connector.
On the new connectors I have there is also one thicker and one slightly thinner
cable, problem is if I connect the thick wires together and the thin ones together the thick wire enters the left hand side of the connector instead of the Right hand side.
Doesn´t it matter which way around the injector is poled or do I need to connect the thin wire from the wiring harness to the thick wire of the connector to keep the polarity the same ?
any advice as always greatly appreciated.
Maz
okay...sorted, My mistake, I should have used google before posting ..sorry :(
Injectors don´t have a polarity, it doesn´t matter which way around the cables go. The + sign on some injectors are apparently to allow a technician to match the terminal polarity to the terminal of the harness.. helpful for diagnostics.
cheers
