Me again.
So I have two questions:
RobHowl ·
Hey guys
While replacing No2 injector I dropped one of the screws from the cap into
the engine bay :ohmy:. I think it may have rolled into the back part of the cambelt cover.
Is it now time to panic and take everything apart on a quest to try and find
the bolt ? Or is it more likely that it will not cause any damage and just "drop" somewhere.
Maz
