Anybody know how overdrive JDM speed control (ASCD)
I bought JDM TT and maximum speed control is 68 mph. It is too small. US and europe version have 110 mph speed control.
How adjust speed control ECU for larger speed?
Any resistors must be remove/adjust.
If I remember correctly, you'll need to swap one part for a UK version - probably the ECU - then it will change the limits for you.
Correct. The ACCS ECU in passenger footwell can be swapped for a UK/Euro version. They are are readily available from breakers.
I have JDM 93 speed control ECU with 20 pin connector. I don't know where I can buy UK 93 version?
I would rather modify my JDM speed control ECU, but I don't know how.
I don't know which resistors modify?
Believe me mate, I had a go at modifying the original ECU and it is just to fiddly. You would probably damage the board having a go and if you were to send it to a professional it would cost more than buying a UK spec ECU.
Trust me - don't bother trying to convert it.
Place a request in the wanted section. They are a few people breaking cars for spares.
