have i bent my brake disk???
just skimmed my R33 skyline disks in work they are to within 0.02mm on the lathe so there quit true,
now when i fitted the passenger side the disk was missaligned against the hub and got trapped in the caliper, so when i bolted up the caliper with the extension brackets it has pulled my disk over :hammer::hammer:
when i took the zed out for a spin there was huge brake judder even came through the brake pedal!! is it possible i have bent the disk slightly, i know there cast and im lucky it didnt crack :bored:
any thoughts gents
Try removing the disc and turning to another set of stud holes in case the run out is at the hub.
Jeff
Jeff
Good advice there jeff cheers will take a dti home with me too see what its like :mellow:
