i borrowed a brake bleeding kit from a mate to bleed my brakes and non of the adapters fitted, so any1 know a kit that will fit the zed, as in the end i had to do it the old fashioned way and it gets depressing :thumbdown:
I had the same problem and guys in the shop trawled through catalogue's and found nothing. I pinched one of the clear pipes before i took the kit back and did it the old way
You will find the gunson easibleed kit will not work, even with the universal adaptor you can buy from them directly. I tried it, didnt work did it the old way.
You could try and modify and old brake cylinder cap, but as its double skinned, its a pain. I find the best thing is the self bleed pipe from halfords, its around 6 quid and has a non return valve, so you can do the pedal on your own and once the air is out, tighten up the nipple and your done. HTH
