Front upper arm bushes
Anyone had any dealings with these bushes , thinking of re-furbing my arms and these you can adjust to alter your camber ????? but how , without pressing them out and re-fitting it again and again until you get the correct camber reading , unless there,s flats on the ends of the bush to get a spanner on and turn them like snail cams , i,m confused :yes::yes:
http://cgi.ebay.co.uk/Nissan-300zx-Z32-Coupe-Control-Arm-Upper-Inner-Outer-Ec-/370299886554?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item563797dbda
its the tube that runs throught the bush that is concentric so you can turn that
i was not aware of this kit but looks quite good, on the other hand i thought the oe arms used roller bearings of some sort and it would be strange to try to replace them with poly bushes
Edited by dougal200
its the tune that runs throught the bush that is concentric so you can turn that
i was not aware of this kit but looks quite good, on theother hand i thought the oe arms used roller bearings of some sort and it would be strange to try to replace them with poly bushes
Cheers bud :clap:
boldy, fyi, they are to replace the rear camber arm bushings which already have eccentric bolt adjustment as oem. they replace like for like but with poly... for the fronts you'll need either a shim kit or the adjustable arms.
Oops , well spotted Joely , i must learn to read one day ! lol
