Niggly whirring noise!!
I got a whirring noise just started.
Not particularly loud. Doesn't happen when in neutral, but when in gear happens intermittentley. Bottoms out the faster you go. 1st and 2nd is noticeable.
It's and Na manual
Any thoughts!!
I've just played around with it, and standing neutral if i switch the aircon off it goes away and then put aircon back on it comes back, the sound is coming from OS around glovebox area.
I had it re-gassed the other week and had no leeks.
The sound is more gurgly than whirring now a sort of gurgly whirry noise, bit like how darth vader sounds when he's breathing
are you sure its not coming from above you head by the map reading light . theres a little fan in there that often makes a noise .
It's gone away for now, but it'll be back later, but i'm pretty sure it wasn't that close. I'll double check. it's like it came from behind the glove box, but i was sat in the drivers seat at the time. And it did sound a bit liquidy
if it sounds like a bubbling noise its probably the AIV ,s . located behind the splash guards under front wheel arches . they gather water over time . simple fix , just undo the clips and let the water out . mine used to sound like a jacuzzi . there is 1 both sides
Should they be affected by the speed of the air-con
Could be the rubber that goes round the gear stick has come away, its there to stop the gearbox noise.
