coil pack problem
any1 know where i can get a set of coil pack connectors for my 300zx twin turbo fairlady must be in good condition
hi on way home today i lost all boost it was fine 1 minute and the next nothing the boost gauge only goes to 0 no higher any ideas car is getting on my nerves now
hi i was coming home and everything was fine then i had no boost at all. the boost gauge only goes to 0 and no higher car is getting on my nerves now
severe boost leak, possibly Intercooler pipe or one of the large intake pipes between turbos, Intercoolers and throtte bodies
look at the top hoses and they seem fine will i need to jack up the car to see the other pipes
Are you in this weekend, if so ive got a few bits to do on my zed saturday morning, but afternoon is clear, plus i can bring loads of spares, ie coil packs, maf, tps etc. plus i have a good idea of how things should be on zeds.
if needed, have a look at this link it might help locate it
http://www.300zx.co.uk/forums/showthread.php?t=115751&highlight=diy+boost+leak
let me know if you need help.
i dont ask anything in return, just make sure i get a cuppa.
stu
hi stu thanks for the offer and the kettle will be on my mob number is 07546222767 let me know what time thanks very much. the car starts and runs ok but the boost is down checked the intercooler pipes could nt see anytrhing wrong but found 1 on the bov valves was loose so tightened it up but still no boost past the 0 on the gauge let me when u can come up thanks mark
also can hear a noise when u switch off the engine sounds like a turbo still spinning maybe a pipes come off the turbo
will call you tonight mate. if all goes well with my zed should be over early afternoon satuday.
stu
had stu come over today and we couldnt find the boost leak any1 know some1 with a lift to put the car on to get a better look at the pipes underneath.
finally got car back from garage and turns out a electrical prob. put new coil pack connectors on and fixed the detonation plug wire and car runs great any1 know any1 who can fit a kph to mph converter on my clocks thanks
  • 4 weeks later...
car now starts to cut out especially when you are stopped or are stopping. sometimes it cuts when you put it into drive it starts to sputter and the revs are erratic any help is greatly recieved could it be the ptu its the series 1 one if so any1 got a series 2 one for sale
