Help Help Help!
Hi Guys,
Can someone help me today?
Ive down tools on the Zed for a few weeks now as i kept coming to problems after problems! But today i want to get cracking and get this problem out of the way:tongue_smilie:
Could you kindley measure the distance from the back of the plenum to the bulkhead? and also state where abouts you measured from as this would be a great help.
The reason being my down pipe is rubbing on the steering shaft and i need to get the engine correctly in place to mark the down pipe so it can be altered.
I havent fitted the gearbox so im guessing the engine is either sitting back or sitting forward at the moment.
Dan:euro:
Yer the engine will till forward when you put the gearbox in, its about 2 to 3" gap at the back.
There you go centre of plenum right hand bolt of the two to the bulkhead i would say 75mm
