No power steering!
Why!!!!!!!! cannot believe whats going on with this car!!!, checked fluids and spot on took it for a drive to see if this would sort and .....no it never:angry:
Also when i am in moan mode the car will not tick over poss due to an air leak.
Can i use my boost leak detector with the dual pop set up???
yes just blank one side off for boost leak test!
is the belt on the power steering pump ok? tight or even attached lol ...pump might need attention?
Cannot find my boost leak detector:angry:
belt attatched not slipping, weird really all fine before i removed engine!!!
Also check the fluid, you may have an air lock.
electronic. Try turning the car off and on. It may work again. I've had it twice so far, turned the car off and back on -working
I had the same for a while and used that trick, well until the pump gave in :(
Check the connections on the solenoid on the steering rack
Done looks all ok
Done plenty of fluid and no air in system:wacko:
Done been for a ride around and still nothing!
So i guess i need a new rack:bored::no::wacko:
Was it ok before engine removal?
If so surely it's gotta be something simple.
Does conzult show any errors?
Perfect before Stu, thats what is weird about it!!.
No haven't put on conzult yet i am a bit:scared: just in case i find something else not right:wacko::lol:
does sound like it could be (hopefully) something simple mate, best of luck!
Been thinking could this be something as simple as a hose flattened/caught where engine has been placed onto it in the engine bay?
Did look at the pipes when i first found steering had failed but all look ok....tight but ok!
Yes. Any kink in the pipe enough to stop the flow of fluid could stop it working completely.
pm me your address and ile send mine...when finnished just send back..simples:cool3:
Thanks for the offer Bri, will talk to my mate who has got the car in the morning, if he requires it i will take you up on your offer....never used mine, got it about 5 years ago, could be anywhere!!!.
Dave
Dave
ok Dave let me know and ile 1st class the sucker:wink:
