i knew it....
Well first off, took the car down to my local garage to get them to give me a hand, getting the new exhaust on, managed that, and booked it in for the MOT. well went and finally filled it up and gave it a good run, god is it quick. specially when the turbos get going, gear box is smooth, think i have a warped disk on the front as i got some shaking when braking from 70 down to 40 where it subsided. any way good thing is so far since getting shot of the old exhaust, i have no smoke :clap::clap::clap::clap::thumbup:
anyway picking her up Monday so can let you all know if she passes or not.
tbh I'm expecting a few advisories, and fail on one part.
Edited by vodkashots
Well done bud, at last your nearly on the road!! Fingers crossed for the MOT :clover:
God, i bet you're glad the exhaust cleared the smoking problem. :)
Peter
tell me about it, sounds sweet as well, did notice that the elbow on the drivers side was missing bolts on the studs, so put some new ones on, and was extra nice to be able to drive it.
hope its sorted, but thinking about it, if it is oil burning, would it not take a good few drives before the smoke gets through the baffles and show
have ya changed the pcv valves and hoses, piece of piss job to do
yep, they were clogged to high heaven. oil, oil filter and airfilter change next.
ahwell, all will be fine then bud, makes a huge difference having fresh valaves in there dont it
god, i bet you're glad the exhaust cleared the smoking problem. :)
peter
yeahhhhhhhhhhhh thanks to me supplying the new exhaust lol
mucho appreciated bud, glad i worked on your car mate, just hope the MOT goes smoothly, dropped the car off at RGS motorsports today, MOT tomorrow, ill find out on monday.
pablitos on the left, mine on the right.
I like that pic. I think the Zed can look it's meanest in pretty much standard form.
Ian, i'm pleased that she's up and running, fingers crossed for the MOT.
At least i wont get sprayed next time... I have never seen exhausts spit water like yours did.... it was like a james bond mod :2guns:
Phil, I just had a look at your ride section.
:bow::bow::bow:
very tidy
Thankyou! :)
Ian
Glad you sorted out the smoking, but what about the missing pot? how did you fix that? i take it then its not being scrapped...
glad its quick enough for you, now remember, no thrashing my gearbox..
Rich
Ian
Rich
Oops :whistling:
but in my defence, i needed to give the engine a good run, as its been sitting for a while.
Misfire is my wiring harness, will need to change it at somepoint
Thats okay mate, i thrashed yours last night.... :whistling:
Keep it up mate, i knew if you got the smoking sorted you'd get the bug to keep it going.
Good luck Ian
Rich
