replacement brakes
Hi there im haveing to replace my discs and pads, front and back, im looking threw ebay and notice most discs are for tt,now my car is a n/a import 92,and i was wanting to no can i put tt discs onto a n/a without any modding,now im not rolling in it so just haveing to go for standerd discs and pads,any advise would be greatfull.:blush::helpsmilie:
You should be fine if it is a 92, but double check the dimensions on yours, if they are 30mm thick and 280mm in diameter, then it will be fine TT/NA, rear discs are the same anyway for both HTH
Graham
