Service Time
If you have a look in the online manual, it tells you everything you need to know. The service bits get added to as the car gets older.
The is something in the FAQ bit.
you got the link buddy please i had a quick look but im on my phone so its takes a while to load up
cheers buddy , i was thinking more after market stuff like whats a good oil and fuel filter etc
What you need really depends on how big a service you intend to give the car.
With regard to oil & fuel filters I would only recommend OEM Nissan parts as you're then guaranteed that they work to the correct specifications.
Furthermore, if you wish to change spark plugs then use NGK's; For ancillary belts I can recommend either Gates or Dayco (OEM belts are quite expensive); Cambelt I'd only ever use OEM Nissan.
Anyway, if you've got a better idea as to what you want to "service" then get back to me as I can provide all parts required (not everything is listed on my website though).
Regards,
