Still got shaky streering
Hi guys,
Here's one for you,shaking under breaking had new discs wheels balanced,and new camber arms and she still shakes,any ideas?:cursing::cursing:
do you use the car alot or does it sit in a garage, also have you check the tyre pressure, they wont make much differance but they seem to sort my little shake out once, what about break pads
Hi mate yes it does sit alot but have used it alot lately,tyre pressure are fine break pads got new with discs less than 100 miles.
Maybe more worn joints has done 75ooo miles?
yes wheels were done properly stood there my self when balanced them and put them on the car.
Check the lower ball joints and tension rods for goo oozing out. If the wheels were put on with an air wrench you're discs may have been warped.
  • 5 months later...
Sorry to raise this post again, but did you solve this Gray? And if so what turned out to be the cause.
Cheers.:)
