Offset guide
Is there such a thing as this type of guide for the wheels and fitament of wheels on a zed? (I spent a while searching before this post but didn't come up with anything.)
I'm on the lookout for wheels and I saw a set with the following dimensions:
19x9.0 +42 PCD: 5/114.3 for the front
19x10.0 +37 PCD: 5/114.3 for the rear
I see from searches I have done that a 9.5" rear with a 35" offset has a nice aggressive stance (Funkysi's being an excellent example). However would the same offset be ok with a 10" rear wheel or does the width of the wheel have a significant bearing?
Does the offset on the front make sense with a 19"rim?
I know that the size of a tyre would have a bearing on the fitting in the arch, so for the above I would be thinking of a 265 on the front and a 285 on the rear. Am I correct in my thinking here or would the 265 rub on hard lock? My suspension has been slightly lowered from standard.
Thanks guys.
That offset calculator is brilliant when it comes to comparing proposed wheels to other setups.
